Car was low on gas when parked, now will not start
1998 JAGUAR XJ8
MRSSTRAWBERRY13
V8, automatic, 80,000 miles.
My car was running fine, great the last time I drove it. I was running low on gas so I decided to wait until the morning to get some gas. The next day the car would not start, I added $5.00 worth of gas and it still would not start. All it does is turn over at a steady speed. I was told it could be my timing, is this true?
Jan 7, 2008 at 1:47 PM
FSTRANGER302
  • 117 POSTS
hello, it is true it could be a timing concern. but i actually think the fuel pump is bad in the car. should have some one check the fuel pressure. hope this helps. let me know if i can offer any more info
Jan 19, 2008 at 5:06 AM
BERRYTC
My wife recently parked her car listed above Vanden Plas in the garage with the gas gauge showing below the "reserve" mark. We left town for a few days in another car, and the next time she tried to start her car, it would not start. We added 5 gal of gas to the tank and tried to start it again with no success. The car ran fine before this. I have checked the inertia switch and it is fine. I also checked the fuses for the fuel pump, etc. and they are also OK. The engine turns over with the starter, but will not start. I have not yet disconnected the fuel lines to check for fuel flow or checked the spark, as I am hoping there may be a simpler fix or check I can do. Any advice? Thank you.
Apr 27, 2020 at 5:15 AM (Merged)
FSTRANGER302
  • 117 POSTS
hello, sounds like the fuel pump went bad. i would first try and disconnecting battery for 5 minutes and if the car starts great. if it does not then pull the fuel lines and turn the key on. good luck
