no spark
PLWHITFIELD
I HAVE A 1990 JAGUAR XJ6. IT WON'T START. I CHANGED THE COIL, DISTRIBUTOR, ROTOR, IGNITION MODULE AND IT'S STILL NOT GETTING ANY SPARK...CAN YOU TELL ME WHY I'S NOT GETTING SPARK? THANKS.
Jul 13, 2007 at 4:46 PM
JAMES W.
  • 2,394 POSTS
When you say ign module do mean ign amplifier or ign relay? If you have checked one of these, check the other. Also, do you have fuel at the fuel rail? (key on) If you don't, it could be the main relay, the crankshaft position sensor or the ECM.
Oct 5, 2008 at 11:59 AM
