Intermittant starting fault
COOPE322
  • JAGUAR XJ6
Hi guys,
i have a 1994, xj6 3.2s with 115000 miles on the clock.
most of the time it runs and starts lovely. Unfortunatly it has a tendency to not start after it has been run for a bit, if I leave it for a while or continually try to crank it, eventually it starts. This can be anything from 5 mins to a lot longer.
please help as I am a bit stumped.
Tuesday, August 7th, 2007 AT 1:25 PM
COSTADELBOY
  • 26 POSTS
Check ecu Un plug leave for 20mins to re set, whilst doing this check plugs and pins for signs of corossion as it is common for water to drip onto it and cause damage
Saturday, September 1st, 2007 AT 5:53 PM
