Jaguar Xj6 Hi Beamlo Beam Headlight
GREG RICHARDSON
1988 Jaguar SJ-6, 66,000 miles. This car has a 4-headlight setup. I noticed last night the passenger-side low beam light has gone out. However, when I turn on the High beams, all four lights are on! Any ideas? I've checked all the fuses. I'm not sure how to check/repair/replace the switches, especially since the high beams are on a combination lever on the steering column -- is there a good online introduction for dummies?
Thanks,
Greg Richardson
Feb 3, 2007 at 9:00 AM
JEFTFIELDS
  • 74 POSTS
what has happened is the low beam has gone out in that headlight in your system the two headlights on the outside have both hi and low beams, so just change the out side head light and it should fix your problem.
Feb 3, 2007 at 9:05 AM
GREG RICHARDSON
Thanks! You were right.
Feb 6, 2007 at 11:27 PM
