Electrical PROBLEM
RENJR84
1988 jAGUAR xj6, HAS ELECTRICAL PROBLEMS with 2 windows not rolling down and 2 doors not opening from the outside. What part of the car is mainly used for this so i could figure out whats wrong with it ?
Nov 29, 2007 at 7:18 AM
  • 31,937 POSTS
Hi there,
You will have to remove the door trim to access the window motors, you will have to check for power when operating switch. If no power at motor check for faulty switch. Check door lock adjustment and handle mechanism while door trim is off.
Mark (mhpautos)
Nov 29, 2007 at 10:07 AM
FSTRANGER302
  • 117 POSTS
[quote:5fe4565f84="renjr84"]1988 jAGUAR xj6, HAS ELECTRICAL PROBLEMS with 2 windows not rolling down and 2 doors not opening from the outside. What part of the car is mainly used for this so i could figure out whats wrong with it ?[/quote:5fe4565f84]hello, try disconnecting the battery for 5 minutes, then reconnect it. if this does work the drivers door module is starting to go bad,if this does not try to push the buttons for windows and door locks and listen. if no noise the switch pack is probaly bad hope it helps. let me know if i can help further thanks pat
Dec 5, 2007 at 3:07 AM
