'87 xj6 fuel pump location
OSKEETE
I recently purchased a 87 xj6. Good battery, good plugs, good spark. When i filled the tanks with gas, the fuel did not reach the fuel rail. Does anyone know where the fuel pump is located on this car?
Jan 23, 2006 at 10:59 AM
PEPPERMRJ
  • 1,158 POSTS
Can't say for certain but most fuel injected cars have a pump located in the fuel tank. However looking at the replacement part it appears to be an inline type.
Good luck and let us know what you find. :)
Feb 16, 2006 at 12:46 AM
MATT SPIELBERG
The spare tire is located under a plywood panei in the trunk. Between that plywood panel and the bumper is another plywood panel held down by 5 or 6 screws. The fuel pump is located under that panel.
Feb 17, 2006 at 11:09 PM
