1997 Jaguar XJ6 replacing engine belts
1997 JAGUAR XJ6
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROYCE1
I'm trying to replace both engine belts, as one has shredded off (serpentine) and the v-belt to the P/S unit is in front of the Serpentine belt. how do you get the idler pulley loose to remove the drive belt to the P/S unit ? It's not a spring loaded idler pulley as I'm used to. Thanks in advance
Feb 20, 2010 at 7:35 AM
2CARPRO JACK
  • 11,533 POSTS
If i remeber correctly there is a threaded rod between the pump and the block/mount.You will have to thread the locking nut down to relieve tension on the belt
Feb 23, 2010 at 7:13 AM
