1997 Jaguar XJ6 check engine light
1997 JAGUAR XJ6
80,342 MILES • 6 CYL • 2WD • AUTOMATIC
RJLMLM
my check engine light just came on (book says that it will go into limp mode, but I do not notice any change) I was just going to the store when this happened. what could it be and what can I do. I am able to do some work on this car. The oil was changed at my Lincoln dealer approx. 300mi. ago.
Jul 24, 2009 at 11:03 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Check engine lamps can illuminate for many reasons. You will need to use a diagnostic scanner (or have a repair shop do it for you) to retrieve the trouble code(s) that the vehicle's computer has stored. This will pinpoint the cause of the check engine lamp being illuminated.
Jul 24, 2009 at 11:08 AM
CRAIGINPA
  • 23 POSTS
Many auto parts stores, such as AutoZone, will read the codes from your car for free.
If your car is not in restricted performance, the fault is probably in the emissions system or a transient CAN bus error. Typical problems are loose gas cap and the lamda sensors.
If it's a transient error, you'll see the light go off after 3 successful warm up from cold events. i.e., After the car is cold, you start and drive the car to fully warm. You'll see the light go off when it gets warm on the fourth trip.
Jul 30, 2009 at 5:06 PM
