Hello
The hvac blowers will not run from the control on the dash. The dash control has power and all functions indicate they are functioning properly. I have checked the fuses for both fans and they are both fine. I have powered the fans with a 12 volt source and they both run fine. Could this be a relay that is causing the problem? If so, where would it be located and how do you identify it?
Thanks
Thanks
Dec 2, 2009 at 3:19 PM
