1996 Jaguar XJ6 Replaceing Oxygen Sensor
103,501 MILES • 6 CYL • 2WD • AUTOMATIC
D POTTS
1996, XJ6, 4.0L 6cyl, The right side rear oxygen sensor is bad and has been for a while. Can I replace it with a four wire universal oxygen senor. They are a lot les expensive then a Bosch OS. Is their a cabin air filter on that model?
Dec 15, 2008 at 3:00 AM
JAMES W.
  • 2,394 POSTS
Not knowing what replacement sensor you are looking at, I can only guess. Your existing sensor is heated. Any 4 wire replacement should also be heated. Being an XJ6 owner myself, I would go ahead and try the aftermarket replacement.
Jan 9, 2009 at 2:32 PM
