1996 Jaguar XJ6 fuel pump
151,000 MILES • 6 CYL • 2WD • AUTOMATIC
SEAHAWK108
hi i have a 1996 xj6 vanden plas.drove it to the park ran fine. shut the car off and when i tried to start it, it would sputter for a second and quit. where is the location and how to replace the fuel pump?
Sep 1, 2008 at 11:25 PM
JAMES W.
  • 2,394 POSTS
The fuel pump is inside the fuel tank. You need to drain and remove the tank to get at the pump. Before I did this I wound check fuel flow and pressure at the fuel rail and be sure the fuel pump relay is working. You should be able to hear the fuel pump run for a few seconds when you turn the key to run.
Oct 3, 2008 at 7:40 AM
