1996 Jaguar XJ6 fuel
1996 JAGUAR XJ6
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
TFLOW06
Car stalled on me as if I ran out of gas. Since then I found that I was not getting gas to carb. Sprayed directly into carb. & vehicle started. I then replaced fuel filter which was bad but still no flow. I replaced battery was told battery no good. when I turn ignition on pump seems to be working. stumped!!!!
Feb 18, 2009 at 7:02 AM
JAMES W.
  • 2,394 POSTS
You will need to open the fuel line at the fuel rail and be sure you're getting fuel flow. If not, check the fuel pump and relay.
Mar 30, 2009 at 4:53 PM
