1995 Jaguar XJ6 Starting Problems
FUNAKI1
  • 1995 JAGUAR XJ6
1995 Jaguar XJ6 6 cyl Automatic
Hi, my 1995 Jaguar has problems with starting up. In fact the key wont fully turn when inserted, Is this a problem with the key system or could it be something more?
Thursday, December 17th, 2009 AT 2:25 AM
DAVE H
  • 13,384 POSTS
IGNITION SWITCH & LOCK CYLINDER
Removal & Installation
Disconnect battery ground. Remove steering wheel. See STEERING WHEEL & HORN PAD. Remove steering wheel spline adapter ring. Remove instrument illumination rheostat control knob. Remove lower and then upper cover. Remove column switch-gear mounting bracket-to-upper column securing bolts. Reposition mounting bracket and remove upper nacelle. Reposition switch-gear mounting bracket to all access to ignition switch.
Disconnect ignition switch harness multi-plug. Release ignition switch harness multi-plug. Release ignition switch retaining tags. Remove ignition switch from lock assembly. Using a suitable punch, remove shear bolts securing lock assembly. Release switch assembly. To install, reverse removal procedure, using new shear bolts.
Thursday, December 31st, 2009 AT 8:13 AM
