1995 Jaguar XJ6 NO LINK obdii reader
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
BANDRE111
I have a 1995 xj6, problem is odbii reader is reading no link from the computer. I have tested all pins on the connector for ohms and they all have a ohm reading. When i disconnect the blue wire connector under the center console next to other connectors it gives me other information. But not ECM codes or turning off check engine light. I know its not connecting to ECM for trouble codes. I have extensivly troubleshot
Jun 2, 2010 at 7:13 AM
2CARPRO JACK
  • 11,533 POSTS
Im going to hand you off t our Jag tech to see what he has to say.Be patient he will be with you asap
Thanks for using 2Carpros.com
Jun 3, 2010 at 1:08 AM
