1995 Jaguar XJ6 key won't turn
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
FAWNABE
I drove the car last night and it was fine. This morning I went to start it and the key would not turn over. I don't think it is the battery because the lights come on and the clock is on.
I just recently purchased the vehicle and noticed that when you brake the steering pulls to the right.
Could this be a steering column issue? A key issue?
Please help.
Feb 9, 2009 at 3:14 AM
JAMES W.
  • 2,394 POSTS
Try spraying down the key slot with a spray lubricant of a type and working the key in and out a few times. If that won't do it,you'll have to replace the key tumbler.
On the brakes, check your front brake pads. You may need brakes, or have a frozen brake caliper.
Mar 30, 2009 at 5:22 PM
