1995 Jaguar XJ6 drivers seat
38,796 MILES • 6 CYL • 2WD • AUTOMATIC
JOSEPH.NHI
The drivers seat will not opperate with any of the elect buttons. Have already check all fuses under both drivers side and passager side dash board. The passager side seat is working. The area under the seat did get wet with water recently. Any ideas?
Mar 11, 2009 at 8:15 AM
JAMES W.
  • 2,394 POSTS
Check the connections at the seat motor. If OK, check for voltage at the seat motor connector. If no voltage, its the switch. If you have voltage, it the seat motor.
Mar 30, 2009 at 4:26 PM
