1995 Jaguar XJ6 1995 Jag stalled while driving, cannot rest
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
TEDMCCLURE
My 1995 Jag stalled after driving 60 miles on a road trip. It sputtered abit and then just stalled. Seems like it was out of gas but it had 1/2 tank. Now it won't start and will not even turn over / crank. Lights & LED all come on. Any ideas where to start.
Ted Mcclure
Jun 16, 2010 at 7:39 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation Start by checking/replacing the battery .. if it cranks/starts with a new battery then check alternator is good let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1158.png
Jun 27, 2010 at 9:25 PM
NIKOLI
I had the same problem with mine, I was test driving it and got a clogged gas line and the car died. In my desperation after having checked everthing and it still not working I pressed the fuel tank toggle switch rapidly, after hearing a click in the back I tried to start it again and it started fine.
After looking into it, the problem was the fuel tank switch valve. Apparently if you have an old valve and the fuel flow to it is stopped it can seize in a half closed position not allowing enough fuel to reach the engine.
The valve is located in the rear trunk under the spare tire and it's a little brass canister looking thing that's connected in between the two fuel pumps that are in the rear most portion of the trunk and the fuel filter which is in the front most portion.
Aug 30, 2010 at 5:56 AM
