1994 Jaguar XJ6 stop lighs and turn signal problems
1994 JAGUAR XJ6
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIZZ311
I have a 1994 jaguar xj6, my left front turn signal lights up but will not blink, new blub, fuse good, and wires good to the light. and left rear stop lights will not light up when brake pedal is pushed, but will signal , fuses are good, blubs are new . all other lights work great..........help
Nov 18, 2009 at 7:14 AM
SERVICE WRITER
  • 9,123 POSTS
What bulb number did you put in the left front?
I'd double check that it is the right bulb. IF they are easy enough to get to, swap the two front ones and see if that changes it.
There is a brake light switch at the brake pedal that may bad.
Nov 18, 2009 at 8:58 PM
