1994 Jaguar XJ6 replacement wheel
1994 JAGUAR XJ6
238,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMES BRANDT
I recently had a cracked a wheel. The spare tire also had a matching wheel, so I simply mounted the spare wheel on the auto in place of the cracked wheel. I now need to find a wheel to re-mount and carry as a spare. I am not concerned about a matching wheel. I am simply trying to find a basic, relatively inexpensive wheel to use. However, I am not sure where to find one or if there is a special bolt pattern or depth I need to be looking for.
Jan 7, 2010 at 11:52 AM
DAVE H
  • 13,384 POSTS
you will have to replace with a jaguar wheel rim .. see if your local junk yard can source one for you !
Jan 9, 2010 at 8:56 PM
