1994 Jaguar XJ6 Hazard Lights Will Not Shut Off
1994 JAGUAR XJ6
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
CCHUGHS
I cannot get the hazard lights to shut off. The switch makes no difference in either position. The only way I can get them to shut off is to unhook the battery.
Dec 6, 2008 at 7:36 AM
JAMES W.
  • 2,394 POSTS
Have you tested the switch to see if it is shorted?
Jan 9, 2009 at 3:18 PM
CCHUGHS
I have tested the switch, it is OK. I have since found out that the switch is hooked to a small circuit board along with the headlights and if I unplug the whole assembly the hazzard lights will go off. I am looking for the replacement part now but they seem to be a bit pricey. Wish I knew a way to test for sure if replacing the switch circuit board assembly will solve the problem.
Jan 10, 2009 at 1:21 AM
JAMES W.
  • 2,394 POSTS
The switch board you are talking about is call the
'facia" switch. I had a problem with the same board on my '88. They are available used from some salvage yards around the country. If you have, or have access to, a fax #, I can send you a list of yards who handle Jag parts. Or, you can look on the internet. I got the headlight switch and the VCM panel for $50.You may want to check www.urgpartssearch.com/searchframe.cfm. The board you need is not a normally listed part, but if you ask about an ECM or a blower motor, they will send you a list of yards who have those parts, then you can call or email them about the switch. Hope this helps.
Jan 10, 2009 at 6:50 AM
