1994 Jaguar XJ6 door locks
JALENE
Electrical problem
1994 Jaguar XJ6 6 cyl Automatic 121000 miles
We replaced the outer door handle with a used one. Put the original chip on, along with the pieces needed to make contact, then connected the wiring and put the key in the lock to test it. The locks just go up and down constantly! Any ideas?
Mar 22, 2009 at 2:11 PM
JAMES W.
  • 2,394 POSTS
You'll need to check the switches on the replacement latch to be sure they are opening and closing when the should.
Mar 30, 2009 at 4:22 PM
