Is there an alternate connection in the engine compartment to attach jumper cables in my 1994 XJ6? My trunck is stuck shut.
Jul 17, 2008 at 7:15 AM
✓Experienced Mechanic
Hi there,
You can put the pos on the main terminal on the starter and the earth on the block, trouble is i don't know if you can reach the started easy form the top, have a look before you try, and use a surge protector as well.
