1993 Jaguar XJ6 missing
1993 JAGUAR XJ6
150 MILES • 6 CYL • 2WD • AUTOMATIC
THOMAS FISH
just bought a 93 ,3.2 xj6 and its missing on number 3 ,changed the injectors,did a compression test,showed 10 then did it again and it showed 5,its sparking well and the engine does not smoke. help?
Jul 30, 2008 at 9:31 PM
JAMES W.
  • 2,394 POSTS
Question; What do the rest of the cylinders read?
average good compression should be 150 to 160 lbs.
If #3 is the only cyl. that is low, it's either a burned or bent valve, or a flat lobe on the cam shaft. If #3 "is" the only one low, that rules out head gasket. You can visually inspect the camshaft by pulling the valve cover. Good luck.
Oct 4, 2008 at 2:48 PM
