1993 Jaguar XJ6 FUEL PUMP
TINAJANDA
Engine Performance problem
1993 Jaguar XJ6 6 cyl Two Wheel Drive
CAN I PUT A UNIVERSAL FUEL PUMP IN INSTEAD OF DROPPING THE TANK AND ALL THAT HASSSLE?
Feb 28, 2009 at 12:36 PM
  • 31,937 POSTS
Hi there,
You can run an after market pump, they cam be very noisy though and you will have to match the presser and flow rates, also you may have an issue of drawing fuel through the failed pump, if it was mine i would do the job properly and do the original pump.
Mark (mhpautos)
Feb 28, 2009 at 4:00 PM
