1991 Jaguar XJ6 sometimes crank sometimes nothing
1991 JAGUAR XJ6
69,800 MILES • 6 CYL • 2WD • AUTOMATIC
DEBRY1MIL
When I try to start my car sometime it will turn over, but most times it will not, not even a crank. I put a knew battery. I checked the ignition on relay (fine) When I jiggle the key it will make the instrument on the dash board lights up and flicker like crazy but no crank. I have an antitheft alarm, I believe it is aftermarket, I believe it may have something to do with my problem. Also I purchased a new ignition switch which I was going to replace this weekend. Please help with any advise that may get me back on the road of recovery.
Apr 2, 2008 at 1:54 AM
LEGITIMATE007
  • 5,121 POSTS
I think you may be on the right track. anytime you jiggle your ignition and the lights start blinking you have a problem. before i say its your starter. you should go ahead and put the new ignition in and we'll take it from there.
Apr 2, 2008 at 3:13 AM
