1991 Jaguar XJ6 power to the blower motors
1991 JAGUAR XJ6
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARDRIVER
What is usually the problem if there is no power to the motors all fuses are good is there a relay that could be bad and were is it locaited
Jan 24, 2008 at 8:08 AM
JAMES W.
  • 2,394 POSTS
The relays for the blower motors are inside the housings. Looking at the housing you will see a large damper. Inside this damper, low and to the outboard side, is the relay. Note: these blower motors are notorious for bad brushes in the motors.
Oct 8, 2008 at 4:04 AM
