1991 Jaguar XJ6 Passing Gear
ALLEND73
  • 1991 JAGUAR XJ6
  • 6 CYL
  • 156,000 MILES
156000
When you shove the gas pedal, car seems to just load up and will not go.I can gradually accelerate and the car will eventually go very fast.
Car runs somewhat smooth at start up but goes to a rough idle after warm up.
Sunday, March 28th, 2010 AT 6:58 PM
DAVE H
  • 13,384 POSTS
NO POWER
Check for burned or sticking valves.
Check for incorrect valve clearance.
Ensure fuel system is okay.
Ensure engine compression is okay.
Ensure ignition system is okay.
Check for incorrect camshaft timing.
Check for incorrect octane fuel.
ROUGH/UNSTABLE IDLE
Check for blown head gasket.
Check for an intake air leak. (Idle speed will usually be faster if an intake air leak is present.)
Check for air leaking into or out of exhaust system.
Monday, March 29th, 2010 AT 4:05 AM
