1991 Jaguar XJ6 heater motors
1991 JAGUAR XJ6
CARDRIVER314
Heater problem
1991 Jaguar XJ6 Two Wheel Drive 100000 miles
Is there a relay that could cause the heater motors not to work,if so which one is it?
Dec 10, 2007 at 11:59 PM
JAMES W.
  • 2,394 POSTS
The relay for each blower motor is inside the blower housing. Looking at the blower housing you will see a large damper. Pushing the damper open you will find the relay low and to the outboard side of the housing. Just a thought, are fuses good.
Oct 6, 2008 at 12:02 PM
