How do I locate the brake sensor on the rear brakes? I am having trouble finding them.
Wednesday, February 18th, 2009 AT 5:06 PM
JAMES W.
MECHANIC
There are 2 sensors on each wheel. 1 is mounted on the top of the bearing hub and is for your anti-lock system. The other is actually part of the inner brake pad and is an integral part of the pad and is non-replaceable except with new pads. This sensor will give you "brake pad low" readout on the VCM.
