1988 Jaguar XJ6 Air Pump Hoses
1988 JAGUAR XJ6
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHOOGLEY
I am not able to find/see where the 18'' hoses that connects to the air pump must go. I do find the short one.It was taken off by some one else. I need a diagram or sample drawing of two hoses to and from air pump Thank you.
Jul 5, 2008 at 1:27 PM
JAMES W.
  • 2,394 POSTS
Are you asking about the large hoses that come off the back side of the pump? If so, the long hose goes from the AP intake to the air cleaner housing. Short hose is from AP output to control valve, then to manifold. Diagram should be on left fender well.
Oct 7, 2008 at 4:38 AM
