HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jaguar
XJ6
Engine
Starter
Replace/Remove
1986 Jaguar XJ6 Starter
KODZWALLUP
MEMBER
1986 JAGUAR XJ6
6 CYL
2WD
AUTOMATIC
110,000 MILES
Where is the starter located and how is the best way to remove it. Can I get a diagram anywhere online?
Saturday, May 29th, 2010 AT 11:01 PM
BLUELIGHTNIN6
MECHANIC
Easiest way to find starter is just to follow positive battery cable from battery down through engine compartment, it will lead to starter.
Saturday, May 29th, 2010 AT 11:18 PM
KODZWALLUP
MEMBER
Thank you. Does anybody know the easiest way to take the starter out of a 1986 jaguar xjs?
Saturday, May 29th, 2010 AT 11:48 PM
Please
login
or
register
to post a reply.
Related Starter Replace/Remove Content
1985 Jaguar Xj6 How To Change Starter On Jag Xj6
Hello. Thanks For Being Here To Help Us All Out. I Have Looked At My Chiltons On How To Change Out The Starter On My Jag, But Was...
Asked by
a19thcfx
1 ANSWER
1985
JAGUAR XJ6
VIDEO
Starter Replacement
Instructional repair video
GUIDE
Starter Motor Replacement
A starter motor is a high torque motor that utilizes a small pinion gear to contact the flywheel and a starter solenoid to initiate the electrical connection when the...
1990 Jaguar Xj6 Starter Removal
Engine Mechanical Problem 1990 Jaguar Xj6 6 Cyl Two Wheel Drive Automatic What Is The Easiest Way To Get To The Starter Bolts For...
Asked by
haleytoad
1990
JAGUAR XJ6
1994 Jaguar Xj6
1994 Jaguar Xj6 6 Cyl Where And How To Change Starter On The Jaguar?
Asked by
dan464
1 ANSWER
1994
JAGUAR XJ6
Starter Engages With Shift Lever And When Just Turn...
Car Would Always Turn Over When Trying To Just Put In Neutral. Had To Replace Crankshaft Position Sensor To Get Running, Finally Got...
Asked by
Patrick3772
1 ANSWER
1994
JAGUAR XJ6
1986 Jaguar Xj6 Vacuum Trouble
Hi, And Thank You Very Much, This Page Is Awesome. I Hope You Can Help Me. My Car Is Having Problems, When You Start The Car, Sometimes...
Asked by
comarpe
1 ANSWER
1986
JAGUAR XJ6
VIEW MORE
Starter Replacement
Starter Replacement
