Engine Performance problem
1986 Jaguar XJ6 6 cyl Two Wheel Drive Automatic
Acted like it ran out of gas, would start momentarily but die as if out of gas. Replaced fuel punp, fuel filter, blew out lines, replaced fuel pump relay and cold start relay. Will not start without ether but immediately stalls out. Should I check if the injectors are getting signal (& how) or is there something else I should be checking.
Jul 7, 2010 at 11:04 AM
