1986 Jaguar XJ6 Diagnose Fuel System
1986 JAGUAR XJ6
GREENGOLIATH
Engine Performance problem
1986 Jaguar XJ6 6 cyl Two Wheel Drive Automatic
Acted like it ran out of gas, would start momentarily but die as if out of gas. Replaced fuel punp, fuel filter, blew out lines, replaced fuel pump relay and cold start relay. Will not start without ether but immediately stalls out. Should I check if the injectors are getting signal (& how) or is there something else I should be checking.
Jul 7, 2010 at 11:04 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The first thing we need to know is the actual fuel pressure readings, are you in a position to get a rail pressure test done?
mark (mhpautos)
Jul 10, 2010 at 1:21 AM
GREENGOLIATH
Sorry for the late reply. Will try to get that done tomorrow.
Jul 10, 2010 at 2:42 PM
  • 31,937 POSTS
OK. also have you done a scan for any unresolved fault codes as well?
mark
Jul 10, 2010 at 2:49 PM
