1984 Jaguar XJ6 CHANGING FUEL PUMP
JOXJ6
Engine Performance problem
1984 Jaguar XJ6 6 cyl Two Wheel Drive Automatic
INSTUCTIONS ON HOW TO CHANGE FUEL PUMP ON A 84 JAGUAR XJ6
Nov 23, 2008 at 5:05 PM
JAMES W.
  • 2,394 POSTS
If it's an intank pump. Disconnect the filler neck and wiring, unbolt the hold down brackets or straps. Remove tank and replace pump. Installation is the reverse.
If an external pump, disconnect fuel lines and wiring. unbolt pump from frame. Installation, again is the reverse.
Dec 2, 2008 at 11:42 AM
