car had been sitting for several months without being started - had fuel in both tanks - battery had essentially died - friend and I attached a battery charger for about 30 - 45 minutes - attempted to start - car sputtered and spurted and tried to start but would not turn over completely - we added fresh fuel to one tank - attempted to start it several times and it finally turned over and ran - moved it about 20 feet and let it run for about 30 minutes facing slightly down hill - it stalled out on its own - tried restarting - was able to get it started but it would run for about 5 seconds and stall - in order to get it to run longer than that required the accelerator/gas pedal to be pressed and released, pressed and released, pressed and released rapidly - why will it not run/idle on its own upon initial start up - any help would be greatly appreciated
Jul 31, 2008 at 1:42 AM
