1985 Jaguar XJ6 AUXILLARY RADIATOR FAN
77,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARLGS
My 1985 XJ6 Jaguar has a small auxiallary radiator fan located on the drivers side lower outside corner of the radiator. When i drive the car the fan comes on after a short while then will not shut off until i unhook the battery cable. When i remove power and fan stops it does not restart when i retighten battery cable. Do you know what controls this fan and could i just unhook it and forget it?
Jan 20, 2008 at 11:22 PM
JAMES W.
  • 2,394 POSTS
Have you let the fan run to see if it shuts off by itself after a period of time? Some of these fans are on a thermostat and won't stop until the radiator cools down.
Oct 8, 2008 at 5:31 AM
