HOW DO I CHANGE FRONT DISCS MY CAR HAS FACTORY WIRE WHEELS WITH HUB IN FRONT OF DISCS THANKN YOU
May 2, 2008 at 11:55 PM
JAMES W.
✓Experienced Mechanic
Question: Are you trying to change rotors or pads.
If you are trying to pull the hub, you have to remove the center cap exposing the cotter pin and bearing retainer nut. Removing this will allow you to pull the hub and bearings.
