1983 Jaguar XJ6 Loose steering
12,500 MILES • 6 CYL • 2WD • AUTOMATIC
AWESOMEP6
My vehicle steering is loose from riht to left.The steering column is not loose.Just much play in wheel to turn.Thanks!
Dec 16, 2008 at 5:36 AM
  • 31,937 POSTS
Hi there,
you will need to check the steering rack for worn attach points, also the attach clamp for the steering column to the rack pinion, check for leaks and worn tie rod ends, start here.
Mark (mhpautos)
Dec 16, 2008 at 7:32 AM
