1977 Jaguar XJ6 Tachometer & windshield wipers
CLASSICJAG
Electrical problem
1977 Jaguar XJ6 V6 Two Wheel Drive Automatic 66K miles
Suddenly both my tach & windshield wipers have stopped working. Checked fuses and all are good. Everything else works perfect. Is there a relay switch for just these two? If so, where is it and how do I know which one to replace?
Dec 7, 2007 at 5:28 AM
JAMES W.
  • 2,394 POSTS
The two are in no way related. you have 2 seperate problems.
The tack receives it's signal from the ignition system. I would guess-a bad tach.
Wipers- switch, module or motor. I would check for power at the motor first.
Oct 6, 2008 at 11:36 AM
