1970 Jaguar XJ6 rear brake calipers
PAUL CLEMENS
Brakes problem
1970 Jaguar XJ6 V8 Two Wheel Drive Automatic
how do you remove the rear brake calipers without removing the whole rear end ? is this possible.?
Dec 3, 2007 at 10:10 AM
FSTRANGER302
  • 117 POSTS
[quote:6675933ff6="paul clemens"]Brakes problem
how do you remove the rear brake calipers without removing the whole rear end ? is this possible.?[/quote:6675933ff6]if the calipers are inboard next to the rear diff then no you would have to remove calipers. if you are just replacing pads there should be two pins on each caliper you can remove to replace the pads hope it helps pat
Dec 5, 2007 at 3:08 AM
