1986 Jaguar XJ12 Long or short wheel base?
150,000 MILES • V12 • 2WD • AUTOMATIC
JOHN55Y
Thanks for cracking the code. Do you know if the 1986 XJ12 came in C or L? or both?
Feb 21, 2009 at 9:58 PM
2CARPRO JACK
  • 11,533 POSTS
I forwarded your link to the Moderator that was helping you before (GFIMotorcars) he should be back to you shortly
Thanks for using 2CarPros.com
Feb 22, 2009 at 1:23 AM
GFIMOTORCARS
  • 673 POSTS
1986 Jaguar XJ12
This vehicle (aka XJ-S) was available in one length in 1986. The length would be classified as long since the vehicle is a 2+2 passanger. In 1987 Jag produced a XJ-SC which was a 2 passanger V-12. So knowing that the 2 seater is classified as a short length, then we can consider the 1986 XJ-S a long length, however according to Jaguar and collector data it is classified officially as neither. The 1986 XJ-S has a wheelbase of 102" and an overall length 191.3". Original sticker $36000. A total of 4,885 XJ-S vehicles were sold in the US in 1986. Equipped with a 60 deg V12 overhead cam engine, aluminum block and heads. Displacement of 326cid (5343 cc). Brake horsepower is 262hp at 5000rpm. Torque is 290 ftlbs at 3000rpm. This vehicle also has electronic fuel injection.
The XJ-SC sold as a 1987 model began US sale in spring 1986. This vehicle was equipped with a targa top and may easily be confused or may have even be represented as an 1986 model because of it's early release. The tell tale sign will be the XJ-SC is a two seater.
Feb 22, 2009 at 4:46 AM
