2005 Jaguar X-Type Replacing AC Compressor
MAHERT
Air Conditioning problem
2005 Jaguar X-Type 4 cyl Two Wheel Drive Manual
Can anyone advise what is required to replace the AC compressor on a 2005 2 Lt Diesel X Type jaguar.
How is it accessed and what needs to be removed to enable compressor to be replacem.
Thanks,
tommy.
Oct 27, 2009 at 10:04 AM
DAVE H
  • 13,383 POSTS
Air Conditioning (A/C) Compressor
Removal
Reclaim the refrigerant. For additional information, refer to CLIMATE CONTROL SYSTEM-GENERAL INFORMATION .
Raise and support the vehicle. For additional information, refer to .
Detach the accessory drivebelt.
Using the special tool, rotate the belt tensioner counter clockwise.
Fig. 2: Detaching Accessory Drivebelt
Courtesy of JAGUAR CARS, INC.
Disconnect the electrical connector.
Fig. 3: Disconnecting Electrical Connector
NOTE:Seal the tube and the compressor with plugs
Fig. 4: Detaching Compressor Supply And Return Tubes
Detach the compressor supply and return tubes.
Remove and discard the compressor O-rings.
Fig. 5: Removing Compressor O-Rings
Remove the compressor.
Fig. 6: Removing Compressor
Installation
NOTE:Install new O-ring seals.
NOTE:Coat the refrigerant line O-ring seals in clean refrigerant oil prior to installation.
NOTE:5oz of oil are contained in the new compressor. The air conditioning system requires a total of 7oz of oil.
To install, reverse the removal procedure.
Tighten to 25 N.m.
Fig. 7: Tightening Bolts With Torque Specification
Tighten to 25 N.m.
Nov 30, 2009 at 11:36 AM
