2005 Jaguar X-Type OIL CHANGE
47,995 MILES • 6 CYL • AWD • AUTOMATIC
GABRIEL JOHNSON
I AM LOOKING INTO BUYING THIS TYPE OF CAR. I JUST NEED TO KNOW ,IS THE UPKEEP EXPENSIVE? HOW MUCH FOR AN OIL CHANGE? I'VE NEVER OWNED AN EXPENSIVE CAR LIKE THIS BEFORE. THANKS ALOT.
Jan 24, 2009 at 3:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
All vehicles run on the same basic concept. It is just a matter of having a local reputable shop that can work on that specific make and model of vehicle just in case you do need repairs done. Upkeep is the same as any other vehicle. All of the maintenance intervals/procedures will be listed in your owner's manual. Cost for oil change will be around $60 at your local Jaguar dealer or around $30 at a local repair shop, depending on the brand/type of oil you purchase. This is average price for oil change on any 6 cylinder motor. You may also want to get the VIN from the vehicle and ask your local dealer if there are any recalls needing repaired on the vehicle.
Thanks for using 2CarPros.com!
Jan 24, 2009 at 3:53 PM
