2004 Jaguar X-Type no start
43,000 MILES • 6 CYL • AWD • AUTOMATIC
BRIANSANTLY
  • 8 POSTS
car cranks but don't start, with scanner hooked up, no codes, in data mode shows no rpm's when cranking, thanks for any help,,,car ran perfect, died on interstate
Mar 18, 2010 at 5:36 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 18, 2010 at 11:32 AM
