How do I bleed the brakes?
DAVIDDIAZ3971
Let the brake fluid run out from the passenger rear caliper.There was no fluid in the master cylinder.Just replaced the drivers side caliper.Put in new fluid .Fluid coming out of the front pasenger caliper when it is bled.Also the rear drivers side is flowing.Cannot get fluid from the rear passengers caliper or the front driver caliper.Is there a special procedure to bleed brakes on thi car/
Mar 22, 2010 at 7:34 AM
MERLIN2021
  • 17,250 POSTS
Here is a video and guide below to help you bleed the brake system correctly.
https://youtu.be/w7gUsj2us0U
and
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
and
https://youtu.be/WDxvEQrMkBg
Mar 22, 2010 at 7:49 AM
