2004 Jaguar X-Type
DENVIL
  • 2004 JAGUAR X-TYPE
  • 6 CYL
  • AWD
  • MANUAL
  • 51,324 MILES
R&R eng.(REPL BRNS). ENG STARTS, RUNS, RUNS SMOOTHLY BUT CHK ENG LT IS ON & NO RESPONSE FROM ACCELERATOR. HOW DO I CHK FOR TROUBLE CODE WITHOUT A SCAN TOOL. ALSO WANT TO DRAIN TRANS (MANU) FLUID. WHAT TYPE & HOW MUCH SHOULD BE USED.
Tuesday, June 16th, 2009 AT 7:58 PM
DAVE H
  • 13,384 POSTS
You cannot check for fault codes without a scantool !
Transaxle Draining & Filling
Raise and support the vehicle.
Remove the drain plug.
Install the drain plug.
Remove the fill plug.
Fill the transaxle to 0.5 mm (0.02 in) below the lower edge of the fill plug bore.
Install the fill plug.
Lower the vehicle.
Wednesday, November 25th, 2009 AT 9:52 PM
