2003 Jaguar X-Type Rear End Slide
120,000 MILES • 6 CYL • AWD • AUTOMATIC
RIKKROTO
Rear end slides sideways when going over bumps. Mechanic replaced the Rear Lower Front Control Arms and then replaced Rear Shock Absorbers. Spent a grand and the problem still exists. Can you advise as to what problem I should look for before spending any more money? Thanks.
Rikk
Dec 13, 2009 at 11:05 PM
  • 31,937 POSTS
Hi there, Thank you for the donation,
I would be taking a close look at the sub frame mounting bushes, sway bar mounts, check for a broken sway bar, i would recommend that a Jaguar trained mechanic or someone with a good suspension background inspect this problem.
Mark (mhpautos)
Dec 14, 2009 at 7:41 AM
