2003 Jaguar X-Type Engine is running hot
101,497 MILES • 6 CYL • FWD • MANUAL
TZDWN2
What could the problem be....I added radiator fluid but it still run hot.
Apr 15, 2009 at 1:41 PM
  • 75,988 POSTS
Are the fans coming on? If so change out the thermostat and see what happens don't work get it block and pressure tested this will telll you what's going on. Check for a clogged radiator and defective water pump.
Apr 15, 2009 at 1:46 PM
TZDWN2
Yes, both fans are running when car is on and after I park to cool the engine down
Apr 15, 2009 at 1:49 PM
TZDWN2
Where can I get it block and Pressure tested? I don't want to take it to the Jag dealer just yet, If I don't need too.
Apr 15, 2009 at 1:52 PM
TZDWN2
[quote:709c29f9a9="rasmataz"]Are the fans coming on? If so change out the thermostat and see what happens don't work get it block and pressure tested this will telll you what's going on. Check for a clogged radiator and defective water pump.[/quote:709c29f9a9]
Apr 15, 2009 at 1:56 PM
  • 75,988 POSTS
Start by replacing the thermostat and see what happens
Apr 15, 2009 at 2:08 PM
