2004 Jaguar Vanden Plas air filter
2004 JAGUAR VANDEN PLAS
JSPKS43
Engine Performance problem
2004 Jaguar Vanden Plas V8 Two Wheel Drive Automatic
how do you change the engine air filter, and the cabin air filter
May 8, 2010 at 1:37 AM
DAVE H
  • 13,384 POSTS
CABIN AIR FILTER
Removal & Installation (2004-2006)
Cabin air filter is located underneath the right side of the cowl vent. Detach the retaining tangs and remove the cabin air filter housing cover.
Depress the cabin filter retaining plate tangs.
Removing Cabin Air Filter Housing Cover
Swing the cabin filter retaining plate down. Remove the cabin air filter.
To install, reverse removal procedure. Make sure the new cabin air filter is fitted correctly, with the air flow markings on the cabin air filter showing the direction of air flow.
May 8, 2010 at 9:05 PM
