1999 Jaguar Vanden Plas wont start
76,000 MILES • V8 • 2WD • AUTOMATIC
DOUBLEDEUCE2500
i have a 1999 jaguar vdp, i had the fuel pump replaced when it went out, and it has run fine since, then i replaced the battery just because, and it has run fine after that, then i went to drive it one day and it wouldnt turn over, i took it to a mech who told me it needed a new motor, well that just didnt sound right so i brought it back home, can some one help me please? it tries to turn over but doesent
Dec 22, 2009 at 11:41 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard.
Dec 22, 2009 at 6:29 PM
